Can you reuse/modify the lt1 knuckle for the LS1 brake upgrade?
Old Mar 23, 2005 | 01:17 PM
91RSLT1's Avatar
I have the LS1 calipers only and was wondering what else I needed, and if I can just modify the stock lt1 knuckles. I did many searches and from what I gathered I can reuse my lt1 hubs, but I will need the caliper mounting brackets, and ls1 knuckles (maybe). I am going with new rotors in the front and new pads so those will not be needed. Can't I just cut of the 'ear" on the knuckle? Any links of what or where to cut?
Old Mar 23, 2005 | 02:46 PM
Re: Can you reuse/modify the lt1 knuckle for the LS1 brake upgrade?
AFAIK, you must use the LS1 knuckles.
Old Mar 23, 2005 | 04:50 PM
pHEnomIC's Avatar
I really wouldn't try, you should be able to get them cheap and its safer than having 2 pieces or a shady modification. Besides, the ls1s are lighter so you save some weight.
Old Mar 23, 2005 | 05:14 PM
91RSLT1's Avatar
Ok guys thanks for the replys. That is all I need to know so that I can start tracking down the parts I need.
ddr698
Jan 9, 2015 10:05 AM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
