Can LCA be set too low?
I have the hardest time hooking up at the track. Mostly I think it's my right foot control, but even pedaling I don't hook until half way through 2nd gear. I'm starting to wonder if I have my BMR LCA too low on the relocation brackets. They are bolted to the bottom hole. Could that cause problems?
Some relevant mods:
M6, 10 bolt, 4.10 gears, nitto DR, spec 3, tubular lca and phr, SLP sfc, stock springs, bilstein hd rear shocks
Some relevant mods:
Some relevant mods:
Some relevant mods:
At least I win something this year. This douchbag hangs a wheel with a STOCK motor tho', no hooking problems here, just tryin' to help you see that a lack of a torque-arm is a traction problem for many. May not be your only one however.
Some relevant mods:
Some relevant mods:
