C5 brakes on an LT1
Old Oct 27, 2006 | 01:20 PM
Lees94Formula's Avatar
C5 brakes on an LT1
I'm trying to put together a c5 brake setup for my car and I'm looking for the best deal on some conversion brackets. I found these on ebay http://cgi.ebay.com/ebaymotors/93-02...QQcmdZViewItem
Does anyone recognize these as a quality part? I know UMI makes the brackets but they are a bit more expensive. I see these are cut from 304 stainless steel..whats the difference between these and the UMI and "Bob Bishop" ones I see in the group purchase section? Also if anyone has a COMPLETE parts list for what I will need or a writeup I would greatly appreciate it.
Old Oct 27, 2006 | 02:47 PM
OBE1 95Z28's Avatar
The 13" C5 rotors/calipers don't fit all the different 17" rims; verify it will work with your rims before proceeding.
Old Oct 27, 2006 | 03:31 PM
I have gm SS 17x9 wheels..
Will I have clearance issues?
Old Oct 27, 2006 | 07:02 PM
OBE1 95Z28's Avatar
Those will fit just fine; my friend did the C5 upgrade with the same wheels. Unfortunately my Enkei 17 X 9.5 wouldn't clear the C5 setup; I went with the Baer Track Kit (C4 setup) setup that just barely clears.
Old Oct 27, 2006 | 07:26 PM
Severous01's Avatar
my boyd's didnt fit either. i swapped to zo6 wheels. they have plenty of clearance. anything that actually came on a vette will fit.
also, the brackets that are on ebay arent high quality parts. some could be, but they werent anywhere near the quality of bob's brackets. he actually spec'd out each unit for clearances and tolerances. i doubt anyone else does that.
Old Oct 28, 2006 | 04:11 AM
RE AND CHERYL's Avatar
Bob's brackets are tops but those are 1/2" thick stainless so they should be plenty strong. The only thing I'd be worried about would be clearance and the brackets fitting like they say they will.
Old Oct 28, 2006 | 07:00 AM
Jon A's Avatar
Bob's brackets (now TrackBrackets) are made from Aluminum. The difference is they are machined from one solid chunk of billet. These Ebay brackets look to be two sheets stacked on top of each other which shoots their bending stiffness all to hell with two chunks of aluminum tubing sitting on top for each bracket. I'd go Trackbrackets, UMI or LG before I'd waste my time with these.
Old Oct 28, 2006 | 12:38 PM
Bud M's Avatar
http://www.speedspecialty.com/store/...=c5fbodybrakes
scroll to the bottom for a link to the C5 brake parts list
compare the pictures of the trackbrackets to those ebay brackets and you will see why the ebay ones look like trouble
Old Oct 28, 2006 | 10:56 PM
68z28's Avatar
Try Tobin at Kore3. I got my pads, rotors, braided lines, and conversion brackets from him. Flawless customer service. www.kore3.com
Old Oct 29, 2006 | 01:05 AM
I think I've narrowed it down between the UMI or those at Kore3. Are either of these cut from a single chunk of metal? I know this is not a part to be cheap on but I refuse to spend 300+ on the Trackbrackets. My car will never see abuse but I also dont want something thats going to break if I decide to stop quickly. Have either of these companies load tested their brackets?
Old Oct 29, 2006 | 03:39 PM
5.0THIS's Avatar
Some people are just cheap and refuse to spend money for good parts.
Old Oct 29, 2006 | 08:36 PM
68z28's Avatar
The Kore3 Brackets are definetly a quality part. Mine are one piece. His brackets are stress tested and have been problem free. Because you ^^^ overpaid, that makes me cheap??
Old Oct 29, 2006 | 09:21 PM
NOSCaMaRo's Avatar
By looking at the Kore3 brackets they are 3 pieces welded together, one flat plate and two round metal tabs welded on. The UMI and trackbrackets are both machined from one solid chunk of aluminum. I have never heard of failure on either of them. I have heard with the Baer brackets, which look the same as the Kore3 brackets is they flex and allow uneven pad wear, this would be my concern with them.
Old Oct 30, 2006 | 01:26 AM
5.0THIS's Avatar
I paid 210$ shipped for my brand new aluminum Bishop brackets, before he stopped making them himself. I will pay more for quality parts, because they're my brakes, and I'm not a cheap bastard when it comes to such important components.
Old Nov 6, 2006 | 09:23 PM
Jim D's Avatar
I've got 13" C4 HD brakes under my 16" IROC rims...just got to get the right set up (or know someone else that has figured it out).
jb4xx
Feb 2, 2015 10:00 PM
ddr698
Jan 9, 2015 10:05 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
Jul 4, 2005 05:00 PM
vals95z
Mar 18, 2003 03:45 PM
