Bushings Press
Bushings Press
Has anyone ever used something similar to this tool? Its a bushing driver set that JP Whitney sells. I'm considering purchasing ot to remove/install my ES Poly bushings, if its cheaper than having a machine shop charge me for each press. Thanks
http://www.jcwhitney.com/webapp/wcs/...Group&ss=10101
Which bushings are you trying to replace? I did the entire ES "master kit" and nothing in the kit required anything more than a c-clamp to assemble the ES poly bushings. It was necessary to "burn" the old stock bushings out with a propane torch - but no press required.
Fred,
I wanted to replace Frt/rear control arm, and panhard rod bushings. I wasn't looking forward to burning them out. Do you think this tool will work? I was thinking it'll be cheaper then having them all pressed out/in.
The tool may help in that it will press out some of the old rubber bushings. The problem is that the old rubber bushing are melted into the shells and when you press them out, some rubber still remains on the shells and it must be burned out.
Aaront810
Aug 29, 2020 09:34 PM
Sep 18, 2015 03:46 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
zajones
Jul 30, 2015 02:18 PM
