Break dash light, brakes need pumping
Old May 23, 2006 | 12:12 AM
Dansean1's Avatar
Guys, need some help. In the last 3 weeks, I have had to at various times pump my brake pedal to stop adequately. My brake dash light comes on intermittently and one day I suspected I saw brake fluid leaking from the point where the master cylinder bolts to the brake booster. I also found I was quite low on fluid at that time.
I dont suspect a break in any line but do suspect the master cylinder has gone bad; Im not 100% sure. I bought a new cylinder but it requires me to transfer my old reservoir over- is that difficult to do? SEcondly, Im aware the brakes will need to be bled afterwards. Is there any harm in waiting a day or so since it is a 2 man job?
Any insight?
thanks
Old May 23, 2006 | 07:52 AM
Dave K's Avatar
Re: Break dash light, brakes need pumping
No it's usually held on with an O-ring (I've never changed the one in my Z but I expect it's similar). You should be able to gently pop it out.
Definitely sounds like the master cylinder.
warmeck
Feb 5, 2015 11:04 AM
Brake_L8
Jan 20, 2015 09:44 AM
Jul 4, 2005 05:00 PM
Ken S
Jul 25, 2002 11:23 PM
