braking problems
Old Jun 19, 2006 | 04:20 PM
transAMdriv3r's Avatar
braking problems
hey , i have 1994 trans am with the lt1 and i am currently experienceing braking issues. when i first start out ,the brakes are excellant, but when they get some heat in them the pedal feels spungy and it starts pulsating and the whole car is rocking forward and back coming to a stop at very low speeds, hardly notice it at higer speeds. i just replaced the the front brake pads and the back ones still had a good amount left. i also replaced the front rotors and agian the back rotors were in good shape. i checked the fluid and it is where it should be.
Old Jun 19, 2006 | 04:59 PM
Severous01's Avatar
Re: braking problems
did you bed the rotors? did you clean the rotors before you put it all back together. they come with a rust preventative glaze on them and if you didnt spray it off then you probably warped them...they sound warped.
if you bled the brakes and there is no air in there check your lines for bulging. you may have a near broken line.
Old Jun 20, 2006 | 05:29 AM
ok thanks, ill have to take a look at it. and no i didnt take the glaze off of it. but it feels like its coming from the rear so mabe ill change those rotors and check out the lines like you said.
Magenta_Hearts
Mar 25, 2015 10:24 AM
dluna333
15
Mar 13, 2015 12:30 PM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
