Brakes (pads/rotors)?
Old Jul 11, 2007 | 07:08 PM
JeffsWorld's Avatar
Looking for decent brakes (rotors/pads), not looking to brake the bank, just something that will hold up and NOT be too DUSTY, look better than stock, and hold up to the riggors of the street. Slotted? Cross-Drilled? ...or both? The 'bird is a fair weather car, not being driven more than 1,000mi each year. Are they simplly a plug-n-play? Easy install for the novice? good link? Suggestions? Recommendations? Which vendor(s) have the best pricing? Thanks -Jeff
Old Jul 12, 2007 | 10:44 AM
MARKTHOMASBRAND's Avatar
Hi,
www.ebcbrakes.com
I just installed their slotted and dimpled sport rotors and red-stuff ceramic pads on the front today.
It's an easy install,you'll need a 3/8" allen key/wrench to undo the front calipers,once the calipers are removed the rotor just pulls off .
Make sure you use an axle stand,don't trust the factory jack for anything other than changing a wheel.
I cleaned the hubs up with emery cloth and brake cleaner,same with the calipers.I used some copper grease on the back of the pads also.
Taking your time,you're probably looking at 3 hours tops,it's actually one of the nicer jobs on a 4th Gen .
Just bedding them in at the moment so can't really comment on the stopping power just yet.They look sweet installed and the quality is top notch.
Cost me £208 including shipping,I'm guessing that's about $400.
They're so new I havn't added them to my signature yet,LOL.
Hope this helps,all the best,Mark.
Edit: try www.perfectbrakes.com (US dealer).
Old Jul 13, 2007 | 05:55 AM
This is a pretty informative read also www.brakes4u.co.uk/brake-doctor.asp
Old Jul 20, 2007 | 09:14 AM
CCRJon's Avatar
Stainless Steel Brakes Short Stop Slotted Rotor Upgrade Kits
This is rotors and pads!
Summitracing has them for $289.95
http://store.summitracing.com/partde...0&autoview=sku
I have this - just looking for the money to install it.
Old Jul 20, 2007 | 05:32 PM
96 Z 28's Avatar
Irotors.com are cheaper and basically the same quality rotor $190 for all four
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
