brakes
Old Jun 8, 2008 | 12:43 AM
thebeast93's Avatar
brakes
how hard is it to install new brakes and how long does it usually take?
Old Jun 8, 2008 | 04:04 AM
dregsz's Avatar
If you mean rotors and pads, about 1 .5 hours per side your very first time and maybe 45 min per side after that, including jacking and wheel removal. Check the facs and stickys for instructions and make sure you use Hi temp thread locker.
You can do it w a set of box end wrenches once the wheel is off and a Helms manual is also a very good idea, and will give you full instructions for that job and everything else you never realized y0u could do yourself.
I would call it an easy job and a good first wrenching project.
Old Jun 8, 2008 | 09:06 AM
JakeRobb's Avatar
Super Moderator
After doing it a few dozen times, and now that I have an air impact wrench, a torque wrench, and bigass floor jack, I can change rotors and pads in 20 minutes per wheel.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
