which brake pads on C5 calipers?
If the only thing you change is the caliper, you would use f-body pads.
If you get the vette abutment bracket(some might call it caliper mounting bracket) you could use vette pads.
But I think you'd be better off with f-body pads since they are made for f-body rotors and vette pads are made for vette rotors.
The calipers have the same basic geometry, but the vettes have stiffening ribs and smaller pistons and also are cast differently.
sleeperZ96BT
Sep 9, 2015 08:28 AM
