brake fluid flush--cant get 1 caliper bled
Old May 27, 2009 | 03:04 PM
SS44Camaro's Avatar
today i flushed the brake fluid in my 94z (fluid looke like used oil). everything went good till the front passenger caliper. it stoped sucking fluid, i used mityvac. well while it had vacuum and with the bleed screw loose i pumped the brakes thinking it had some trash in there blocking it and i could push it through. came back around and there was no vacuum and i assume it sucked alot of air in the system. now i cant pull fluid through it only air. i been pumping the mityvac for like an hour trying to get fluid and i only get a little bit with mostly air. anyway i can fix this faster or do i need to just keep pumping. i figured after an hour it wasnt going to work.
what can i do?
Old May 28, 2009 | 07:57 AM
JohnD's Avatar
On a car that old, the brake hose could be collapsing.
Old May 28, 2009 | 10:38 AM
SS44Camaro's Avatar
same thing a friend of mine told me last night. ill get them replaced. there is no way to really check is there? cause its the inner linner that collapses right?
Old May 28, 2009 | 01:42 PM
JohnD's Avatar
Yep. In recent years this seems to be more common than it used to be. Sometimes they will literally form a one way valve when they collapse allowing fluid to go only one direction.
Old May 28, 2009 | 03:15 PM
SS44Camaro's Avatar
i replaced the hose and still nothing. im getting more fluid but still mostly air...
CGM2010CAMARO
Apr 7, 2015 07:44 PM
captcorvette
Mar 7, 2015 12:37 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
Death's.Stalker
Feb 26, 2002 12:53 PM
