Brake Fluid????
Old Oct 6, 2004 | 09:28 PM
Camaro4LifeSS's Avatar
Brake Fluid????
Are their any particular brake fluids that are better than others?Just like to know because i'm fixing to be adding fluid to my ABS delete and thought it would be a good time to see if their's any good stuff.
Thanks,
JE
Old Oct 6, 2004 | 10:30 PM
n2ceptor's Avatar
Re: Brake Fluid????
http://www.tccoa.com/brake-fluid/
Old Oct 7, 2004 | 06:42 PM
Re: Brake Fluid????
I think that i'll go with the usual DOT 3 fluid.Just curious,what fluid is everyone else running?
Also is their any brands that are better than others?
Thanks,
JE
Old Oct 7, 2004 | 07:10 PM
Mtrhds94Z's Avatar
Re: Brake Fluid????
Valvoline 'Synpower' synthetic exceeds DOT 3 & DOT 4 specs..
I use it, no probs here.. Pep Boys etc has it..[WalMart too I think?]
Old Oct 7, 2004 | 07:36 PM
Re: Brake Fluid????
Thanks man,i'll try that.
JE
Old Oct 7, 2004 | 08:44 PM
n2ceptor's Avatar
Re: Brake Fluid????
DOT5 does NOT mix with DOT3, DOT4 or DOT5.1..... If you use a synthetic, the system should be flush out....
Old Oct 7, 2004 | 09:43 PM
Mtrhds94Z's Avatar
Re: Brake Fluid????
If you are referring to my post..note the following..
Valvoline Synthetic is NOT 'DOT 5' [which is Silicone based]
It exceeds and IS compatible with DOT 3 or 4 specs, and it is not 'Silicone base'[DOT 5]
Exceeding DOT 3 or 4, does not make it DOT 5[confused yet?]
You do not need to purge/flush the system to use DOT 3 or 4 in it..
For DOT 5 SILICONE base fluid, yes you would have to get all the ethylene glycol based fluid OUT.. they do not mix..
I believe you have this Synthetic fluid confused with DOT 5..
Old Oct 7, 2004 | 10:15 PM
n2ceptor's Avatar
Re: Brake Fluid????
Old Oct 9, 2004 | 03:02 PM
Re: Brake Fluid????
Does the DOT 3 eat paint as bad as DOT 4 or are they basically the same when it comes to eating paint?Reason i'm asking is I just repainted my engine bay and i'd hate to ruin my new paint so whichever is not as bad on the paint is what i'll go with.I'd like to go with DOT 5 that does not eat paint but i'd rather not flush the system,unless it's something simple to do.
Whats everybody else running,DOT 3,4,or 5?Also,I was just curious,what does DOT stand for?
Thanks,
James
Old Oct 10, 2004 | 08:48 PM
Re: Brake Fluid????
I plan on finishing up my brakes tommorow so if anybody can help on the post above i'd really appreciate it.
Thanks,
JE
Old Oct 10, 2004 | 10:42 PM
n2ceptor's Avatar
Re: Brake Fluid????
I run DOT 4, because of a higher boiling point; I do alot of driving... DOT= Dept Of Transportation
Brake fluid will not eat paint right away... If you spill alittle on the paint just wipe it off ASAP...
As stated in the web site above, DOT3 is the most common.....
Old Oct 10, 2004 | 11:08 PM
Re: Brake Fluid????
I think I will run the DOT 4 as well.Thanks for the info.
James
Old Oct 11, 2004 | 09:46 AM
Mtrhds94Z's Avatar
Re: Brake Fluid????
I know quite a few that use the Valvoline 'Synpower' synthetic.. surprised no one posted but me.. exceeds DOT 4
If you spill it, just get it off fast ..it doesn't eat paint right before your eyes.. if left on there it can though [as will any brake fluid except the silicone based DOT 5]
DOT, yes, means Dept Of Transportation, which sets the 'standards' for motor vehicles in the US..
Bobczar
Oct 23, 2015 11:22 AM
spcearle
Jun 26, 2015 01:11 PM
captcorvette
Mar 7, 2015 12:37 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
Death's.Stalker
Feb 26, 2002 12:53 PM
