Brake booster pump
Re: Brake booster pump
The brake booster is a vacuum canister. There's a larger tube from the intake manifold to the brake booster that generates the vacuum. You'll experince a vacuum leak if the booster fails which can result in a poor idle. A vacuum gauge can help to verify the system. You can also pinch off the line to the brake booster and see if the idle improves.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Ken S
Jul 25, 2002 11:23 PM
