Brake booster issue? after C5 front/ LS1 rear brake install on LT1
Old Nov 14, 2010 | 10:42 AM
ZDriver96's Avatar
I added C5 front calipers and C5 rear calipers w/ LS1 rear rotors to my camaro. I changed all the rubber lines to braided lines including the rubber brake line that sits on top of the axle housing. The brake pedal is now too firm when stopping as if the brake booster is not helping me push the pedal all the way to the floor. I do not get much pedal travel at all. Pressed fully down the car does not come down like it should with C5 brakes. It should stop much harder.
The LT1 brake booster should be strong enough to work with C5 brakes.
Is there any difference between the LS1 brake booster and the LT1 booster?
Maybe it went bad? Stock LT1 master cylinder.
Old Nov 21, 2010 | 04:13 PM
JETMAN95Z28's Avatar
Re: Brake booster issue? after C5 front/ LS1 rear brake install on LT1
I've been considering the same C5 brake conversion you did and have been watching this post to hear the outcome. Have you figured out your brake problem? Thanks
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
vals95z
Mar 18, 2003 03:45 PM
Wilson
Jul 21, 2002 05:08 PM
