Bouncing.
Old Feb 3, 2006 | 12:26 PM
DontMixWithRice's Avatar
Bouncing.
I changed my rear shocks to kyb's in october.
my car is bouncing in a dangerous manner.At high speeds, the car is moving from side to side, and its dropping more on the right hand side...any thoughts on how to fix it?
Old Feb 3, 2006 | 01:22 PM
OBE1 95Z28's Avatar
Re: Bouncing.
Check to see if your panhard bar is connected and not broken.
Old Feb 3, 2006 | 02:25 PM
Re: Bouncing.
yeah ill check that and ill check if my springs are still on tight...you never know!
Old Feb 3, 2006 | 03:53 PM
Greed4Speed's Avatar
Re: Bouncing.
Check all your bolts. LCA, PHB, chocks, etc. Even KYB's shouldn't cause this. lol
Old Feb 4, 2006 | 10:54 AM
lastZ's Avatar
Re: Bouncing.
i had the same problem with my adjustable konis........but it was because i had them adjusted all the way to stiff......pretty stiff ride....but im guessing your shocks arent adjustable....so i dont even know why i even bothered to write this
Old Feb 4, 2006 | 02:12 PM
Re: Bouncing.
well, i still dont know what it is. I dont have any problems with the shocks, I checked today....so i am so lost.
the car went through a swap, and i left the lca's and the panhard off the v6 (they are the same regardless of engine, 82-02) and i changed the rears to kybs before i put the eibachs....
I dont know that to check next.
could it be tires? i recently went from 18s to 16s, and this started
Old Feb 5, 2006 | 11:41 AM
Re: Bouncing.
Did you check the bolts on all suspsnsion components????
Red Hawk 94
Mar 18, 2019 04:03 PM
Rij1
Sep 6, 2011 01:28 PM
Rij1
Aug 28, 2011 08:09 PM
tireburnin
Jan 22, 2010 01:10 PM
