BMR Fabrication Torque Arm
Old Aug 15, 2005 | 08:20 AM
respectirocz's Avatar
does anyone else have this torque arm
and if you do do u have any clearence issues with the torque arm and the driveshaft?
Old Aug 15, 2005 | 11:16 AM
Joe 97RA's Avatar
Re: BMR Fabrication Torque Arm
I have one and there are no clearance issues.
Old Aug 15, 2005 | 12:20 PM
i'm getting a rattle when i drive my car and the rattle increases in frequency with speed,
it is not engine or transmission related
looks like an issue around the rear u-joint
but i didnt spin the driveshaft yet
Old Aug 16, 2005 | 12:38 AM
Bud M's Avatar
What did you set the pinion angle at?
Old Aug 16, 2005 | 08:58 AM
i got the non-adjustable
(which i now regret because i know eventually i will drop the car)
Old Aug 18, 2005 | 11:01 AM
GCEZ28's Avatar
When you lower your car you will probably have clearance issues with the torque arm and the tunnel and possibly with the parking brake cable bracket. I did when I installed an adjustable BMR torque arm.
I cut out a section of the tunnel and welded a piece in to give the torque arm more room. I also moved the parking brake cable bracket to one side about 3/4". No more clearance issues.
Old Aug 18, 2005 | 01:24 PM
i didnt take a good look for any other possible clearance issues
i didnt have any problems putting the torque arm in, at least not with the e-brake cables or brackets
its a pretty loud rattle for what its worth
Old Aug 20, 2005 | 09:55 PM
DarkHorse's Avatar
Stock driveshaft?
Old Aug 21, 2005 | 12:05 AM
Penz's Avatar
This is a little off topic but I have a Universal trak pak or whatever its called. It was on the car when i bought it. It has clearance issues with the tunnel. Whenever I shift hard or anything like it, it bangs against the tunnel. I think the past owner installed it too high when he welded it in with the bar that goes across. Looks like I am probably going to have to cut the weld and redo it. Also, it still has the stock driveshaft.
Old Aug 22, 2005 | 08:45 AM
Bayer-Z28's Avatar
I got the BMR TQ arm w/ the stock driveshaft. Set the pinion angle to -2. I have no clearance issues. THe only clearance issues I have are the Y-pipe for the LT's. But that's a different story.
Old Aug 22, 2005 | 08:21 PM
stock irocz springs, stock ride height
stock rusty old drive shaft,
i'm going to swap the rear for a 89 formula disc brake rear i hope when i bolt the torque arm and the drive shaft to this rear end i'll cure the problem
Quickss96
Jan 29, 2016 05:56 PM
Henson071
Sep 18, 2015 04:01 PM
TGGodfrey
Aug 18, 2015 06:08 PM
realistyc
Jul 28, 2015 07:32 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
