Best pads for C5 front brake conversion?
I am converting my 94 Z to C5 front brakes. What are some good pads at a decent price?
I dont want anything that is going to chew up the rotors, I would also like something that doesnt dust too aweful bad.
Stevie
Stevie
Re: Best pads for C5 front brake conversion?
Originally Posted by unvc92camarors
how are you doing it on your 94?
i heard that the lt1 wasn't compatible with the c5s for one reason or another?
I also have the Hawk HPS pads. Quiet, low dust and they GRIP.
Dan
I am using LS1 spindles and calipers with lg motorsports brackets and c5 rotors.
Should I use pads for an ls1 camaro or for a c5? I think the caliper bracket will accept either, but dont know.
C5 BRAKES ROCK!
Just to let everyone know. You don't need to buy LS1 spindles to put C5 brake swap on!!! I have the C5 setup on my LT1 spindles right now. Get the brake brackets from Matt at Haulin-***-motorsports.com . The price on these brackets is also so much better than other companies. I think it was some where between 180-200 per set of billet aluminum brackets. With the amount of weight you cut off the spindle and removal of the lt1 calipers it actually offset the larger rotors and I think I lost about a pound or two off the front end of the car.
Mikey
Mikey
Magenta_Hearts
Mar 29, 2017 08:54 PM
Jul 4, 2005 05:00 PM
