basic suspension question
Old Feb 20, 2007 | 09:00 PM
pattracing212's Avatar
how much will changing my suspension over to all solid help horsepower to the ground. does it help alot in camaro's. what kind of a difference did you guys see. how many others broke their rear-end's when you did it
Old Feb 20, 2007 | 09:43 PM
2000GTP's Avatar
You can do all of the suspension upgrades in the world, but if you don't have a good set of sticky tires in the back, you will still have trouble hooking up. As for the rearend, it is not likely to break from suspension upgrades.
Old Feb 20, 2007 | 10:03 PM
Bayer-Z28's Avatar
^ W3rd... I have crappy roads here and an almost complete suspension setup. Any other town I grip like crazy, but here, all I do is get sideways..
Better power transfer w/ the BMR ADJ Chrome-moly ADJ TQ arm, I'll tell you that much..
And SFC's are worth their weight in gold!
Old Feb 20, 2007 | 10:07 PM
mdacton's Avatar
If by solid do you mean rod end/heim joint stuff?
if so then do not use it on the street....not good
Old Feb 25, 2007 | 02:14 AM
RedZ28Beauty's Avatar
Why its not good for street???
Thanks!
Old Feb 25, 2007 | 08:00 AM
mdacton's Avatar
DIRT, good rod ends are very expensive.....average $50 a pc.
Plus they ride like $hit, poly stuff is great for the street
I rod with all rod ended stuff on the street...all my rod ends were shot in one summer
Old Feb 25, 2007 | 09:07 AM
respectirocz's Avatar
if you lube your rod ends with a little bit of oil, you'll atract alot more dirt to them wearing them out faster, if you use a graphite lube you might get a longer life out of them on the street
but for daily driving street use, poly bushings will give you the performance u want with considerably longer life
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
