Bad spring, or shock???
Old Jul 1, 2004 | 06:48 PM
gamecockfan04's Avatar
When I push down on the back end of my car easily I here a squeek, creak, from the right rear spring area. Also. starting yesterday, when im at a stop and just let off the brake I here a creak. Is this maybe a bad spring or something else???
Old Jul 1, 2004 | 07:38 PM
n2ceptor's Avatar
insulation bushing on top of spring, LCA bushings, sway bar end link bushings.....Or weak shock...
Could be one or all...
Old Jul 3, 2004 | 12:24 PM
OK. Got under my car today and the sound is coming from my right rear LCA. I can just easily grab it and move a little to make the noise and its mainly where it bolts up to the axle. Can I just remove that bolt on the back of the LCA to check the bushing? Will it "slam" down when I take it out? or is this probably just a bad LCA?
Old Jul 3, 2004 | 02:28 PM
n2ceptor's Avatar
If its a stock LCA, then the bushings are 9 years old and prob cracked... You could just replace the bushings or better yet, purchase an aftermarket set thats a solid piece...
Everyone has their fav... I just bought a set of Lakewoods from Summit back in 2001... Cost was 89.00.... They are factory replacement made of square tubing, poly bushings, and non adjustable... I like them..
Old Jul 3, 2004 | 03:05 PM
camaro325's Avatar
wut does lca mean
Old Jul 3, 2004 | 03:26 PM
n2ceptor's Avatar
Originally posted by camaro325
wut does lca mean
Lower Control Arm.....
Old Jul 3, 2004 | 03:48 PM
TransAm-Z's Avatar
The other option is to turn up your radio and forget all about the squeeks and creeks... Or you could just start replacing stuff...
Old Jul 3, 2004 | 04:17 PM
OK. I took off the RR LCA and just sprayed the hell out of the bushings with WD40, then reassembled it and no more squeeky, creaks,etc...However, I think this is only a temporary fix and Im sure the noises will come back after a while.
Old Jul 4, 2004 | 11:05 AM
Kataklysm's Avatar
Put grease around the bushings.
siguy
Nov 27, 2014 10:07 AM
Victory Racing
Apr 19, 2010 06:08 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
MJ_Z28
Aug 7, 2002 07:15 PM
steve10358
Jul 22, 2002 12:33 AM
