Bad Luck
Old Jun 4, 2006 | 10:53 PM
Dirtbik3r's Avatar
Bad Luck
I know this is a little long, but please read, I need some help and advice from members with more experience than I have.
My car is a 92 camaro rs. There is really nothing on it anymore that resembles the stock drivetrain, interior, or engine.
I recently rebuilt my FORD 9" rearend. I bought a 3.89:1 Richmond gear set, Richmond installation kit, Strange axle bearings/seals, and auburn pro limited slip differential. Before I go any further, let me bring back the past so you [the reader] will understand.
I purchases the rear end from ebay about a year and 1/2 ago. It came with 28spine axles and an open differential. Also, it had the Shock, LCA, and Panhard Rod brackets already welded on. I must say it does look professional, whoever welded it definitely set it up in a jig. The code on the carrier (center section) said it was from a 67 full size Ford car (not mustang). But, it was an oddball. The housing flange resembled more of a Chevy (Special - according to Wilwood). This is sort of like the flanges used on Grand Nationals or camaro's with c-clip eliminators. But it was a big bearing, not a small.
*Note that for the rebuild, I reused the axles since they had the correct offset already for thirdgen camaro wheels.
About a year ago, I wanted disk brakes and turned towards Wilwood. A local reputable performance shop (they have a 6 second 02 camaro out front, not sure which drag class - only stock ness is the firewall and roof) measured, bought, and installed the kit. They didn't have the whole car, just the rear end. They put on the Wilwood dynalite pro series parking brake kit; part number: 140-6699*. This kit is for the small bearing Ford with a 2.66" offset from axle flange to the face of the axle. Wilwood even states, "Make sure this kit is the correct kit to fit the axle housing flange, not necessarily the rear end make." Everything worked well for a whole year until I decided to rebuild it.
After the rebuild, I installed the carrier onto the housing, installed the brakes, and noticed that in neutral with the E-brake not applied, the wheels would not turn.
*I filed down the inside diameter of the studs because I noticed stress crack around the studs holes for the wheels on the rotor. I wanted the rotor to sit perfectly this time on the axle face.
They acted as if the caliper was seized which isn't the case. So stupid me jacked the wheels up and went thought each and every gear. I heard a horrible grinding noise and stopped. The inside of the rotor was destroyed. The bracket kit for the Wilwoods (the part which the caliper bolts onto) milled down the inside of the rotor. WHY would this happen now and not before. I am stumped.
Other thing I noticed include:
axle play on the driver's side. Inward and outward motion. measured: .118" of play
I also measured the offset correctly on each axle:
Driver's side: 2.568"-2.650" (the range is the actual axle end play)
Passenger side: 2.661" with almost no end play. Seems like the bearing is preloaded perfectly.
The other part about the axles which concerned me was how the bearings seated in the houisng. The Wilwood kit came with their own axle retainers with a lip on them. This lip is supposed to face toward the housing (Away from the wheel). Anyway, It almost seamed like the axles were too long and the retainers would only fit flat, the opposite way around without that lip pointing outwards. But, this was the way they have been seated for the past year, when they worked beautifully.
FYI: the rotor is gouged about 20-25 thousandths and Wilwood wants $160 per rotor...
What could cause this to rub now and not before? I'm lost and need help. Is their something I'm overlooking?
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
ducttape1975
Jul 10, 2015 06:29 PM
Boss002
Jul 9, 2015 03:33 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
