A arm seized
Old Feb 14, 2005 | 08:27 PM
Tibbys96Z's Avatar
A arm seized
Has anyone ever had this happen? I guess the bolt that needs to come loose to do an alignment is seized. I just got an adjustable pan hard and adj lca's so they are doing a 4 wheel alignment. But they couldn't get those bolts loose. Anyone?
This is a well respected shop that has done tons of work on my car.
Old Feb 14, 2005 | 10:28 PM
blackztpi's Avatar
Re: A arm seized
always possible to bend an a-arm if you have a bad enough impact with the road or a polhole. that would prevent the bolt from being able to come out straight. most cases come in the shop with a little unintended offroading. lol (usually women) not sure how to diagnose it because i cannot drive your car, but i'd say you'd be good looking into it more from another shop, and then you can always go buy another a-arm from a parts car for cheap.
Old Feb 16, 2005 | 12:02 AM
Z28barnett's Avatar
Re: A arm seized
Been There, here is my old post. Heat pounding and PB blaster got them out, took me about 6 hours for two bolts.
I am in the process of replacing most of my suspension with 1LE parts.
I was doing this in part due to the fact that two alignment shops could not align my car or tell me what was wrong.
My car is a 1995 Z286spd with 90 k miles. I assumed that the bushings were gone and that was causing my problem.
I have been checking every part as I took them off, and until yesterday I had not found a problem.
The bushings are in O.K. condition and tierods/balljoints were ok.
Upper shock nuts where rusted no flats or anything left. Just muddy red rust and flakes. Bottom of the shock tower on the inner fender was begining to rust also and will have to be repainted.
The surprise was the rear front lower control arm bolt. It was frozen beyond anything I had ever seen. After about four hours of pounding with sledge hammers, heating with a Mapp torch, generous aplications of PB Blaster, breaking off the locking tang, I finally got it out.
I am explaining this because the frozen bolt affects the adjustment of the lower control arm and will prevent proper alignment.
The nut came off easily so an aligment shop would think they had loosened the bolt and would attempt to adjust the arm.
The sneaky problem is that you have is the top of the bolt is still clamped. The head of the bolt has not loosened because it is trapped by the rust swaging the shaft of the bolt to the metal center of the bushing.
This means that the arm will not slide and half of your adjustment is defeated. The shop will not know why and in my case they will assume that they have reached the limit of the adjustment. The shop even said that their camber/ caster tool was bending. After removing the bolt I see why.
There is an easy way to check for this problem. If you can't get enough adjustment to do an alignment. Have the shop try to remove the front and rear bolts, one at a time. If they come out easily you are fine and have some other problem. Also if they can be easily tapped part way up and down, you are good. If not, consider your options because this was a very hard job. I had the springs out, so if you are checking with the springs in that may make the test impossible.
The front lower control arm rear bolt was rusted bady over it entire length where it fit into the center of the bushing. It showed no visable sign of this problem. The front bolts looked brand new and could easily be removed.
I think the heat and PB Blaster helped the most. Pounding didn't seem to help much until the bolt started moving. You may want to work on this over a few days and give the pentrating oil more time to work.
I have learned this the hard way and still have two more bolts to do.
I have now completed both sides and the second side had the same problem. Only took about 2 hours of heat and pounding to remove the front passenger side lower control arm rear bolt. The front bolt on both sides was plated and showed no corrosion. I wonder if GM had a batch of bad bolts?
I hope this post will save the owners of camaros time and money on suspension and alignment work.
Front LCA Bolts/Nuts
P/N: 10229835 front (2), 10164163 rear (2), 353773 nuts (4).
Quickss96
Jan 29, 2016 05:56 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
autoxr166
Sep 25, 2015 04:21 PM
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
