A-arm Removal
Old Apr 23, 2004 | 04:33 PM
SATANAZ666's Avatar
A-arm Removal
TO REMOVE THE A-Arm???? Im goint to remove it to get the ball joint pressed out........ is it only 4 bolts holding it in??/ how hard is it???
Old Apr 23, 2004 | 04:39 PM
Bone Daddy's Avatar
Lower: 2 mounting bolts to the subframe, the ball joint nut, and the 2 shock bolts.
Upper: Same, except for 2 more upper mount bolts, and nuts. (You have to remove the strut and spring or it's a 8itch).
Old Apr 25, 2004 | 01:07 PM
OBE1 95Z28's Avatar
You'll need to get the car aligned when you're done, the 2 lower bolts are the adjustment points for alignment.
Old Apr 25, 2004 | 04:23 PM
Bone Daddy's Avatar
Yes, as well as the tie rods.
Old Apr 26, 2004 | 10:07 AM
SATANAZ666's Avatar
AHHH I See, so how long should it take me to pull the things off???
Old Apr 26, 2004 | 12:08 PM
Bone Daddy's Avatar
Well for me, or anyone else that has rebuilt there suspension before, or a few times over, (don't ask) with the right tools and plan, I/we could probably remove one side (2 arms) in about a 1/2 hour or so. But since you don't know the "routine" so-to-speak, it might take you a couple hours. It's not that difficult, it's just a pain in the backside. (*** ) So not knowing your skill level and tool selection it's hard to guess. Just set aside about 1 1/2 hours per side to give yourself plenty of breathing room, and "enjoy".
greenzee28
Sep 25, 2015 04:29 PM
Jake Bialke
Sep 24, 2015 11:31 AM
wbspoon
Sep 19, 2015 08:12 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
