anyones sportlines look higher in the front than the back
I have some eibach sportline springs for my 1996 camaro with bilstien shocks, and it is slightly higher in the front than in the back. Does anybody else have this problem or is something wrong with my springs
Re: anyones sportlines look higher in the front than the back
when i had the sportlines on my car, the front sat much lower than the back..
have you driven the car some so they settle?
hmm, i am not sure, but may there be a travel issue with the bilsteins? i know it is best to have a shock re-valved for the ride height when you have it lowered a decent amount..
Yeah, it should be that way, if you look at your car, the stance is flat. If you lover the front, the car's stance is no longer going to be flat which intended. So yes, the front may look about 1 inch higher.
