anyone make Poly upper strut mounts???
Old Dec 19, 2006 | 09:03 PM
94/96ZsM6s's Avatar
i've got to replace the upper strut mounts on my 94 Z, is there any one that makes poly upper strut mounts?? i've replaced everything else with poly, IMO it makes sense to put poly ones in instaed of orielly replacement parts
Old Dec 20, 2006 | 08:08 AM
Since they are "coil-over" shocks and springs, and not "struts", there's really no advantage in replacing the upper spring/shock mounts with anything other than the stock piece. It isn't going to affect the alignment of the suspension at all, since they are already pretty hard (rubber lined steel) and the only affect of stiffening them would be a tiny reduction in the compression caused by the spring and shock center shaft.
Old Dec 20, 2006 | 12:26 PM
94/96ZsM6s's Avatar
i was jsut curious if there was such a upgrade out there, thanks for the info!!!
dbrockma
Feb 16, 2015 02:56 PM
Jason Short
Jan 19, 2015 06:34 PM
Jul 4, 2005 05:00 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
