Anti-roll bar brackets - cracking
Old Oct 13, 2008 | 12:14 PM
NJ-LE's Avatar
I find my brackets (that hold the bushings and bars to the chassis) are cracking. I've done some web searches with no luck. Does anyone know if there are any after-market brackets (for the factory bars) available?
Old Oct 15, 2008 | 11:31 AM
Bud M's Avatar
If you buy a set of aftermarket bushings they come with brackets. http://www.energysuspension.com/pages/swaybbct.html
I don't know of anyone who sells just the brackets. That would be a dealer or salvage yard item.
Old Oct 16, 2008 | 12:36 PM
NJ-LE's Avatar
Thanks for the reply ... since you're the only one I'll assume this isn't a common failure. These are Energy Suspension pieces. They've been on the car 6 or 7 years ... I guess I got the special "lucky" ones! I'll buy another set. I did the rear bushings at the same time with the ES units and they look to be fine. Shouldn't be corrosion since the car never sees the snow or salted roads. Puzzling.
Old Oct 16, 2008 | 02:41 PM
mrmint69's Avatar
Mine are the same way. They have them at the dealership and they aren't too much.
Old Oct 16, 2008 | 06:39 PM
NJ-LE's Avatar
I dug through the pile in the back of the garage and found my original pieces. Those brackets are too large for the ES bushings. Looks like Summit sells the ES set for 14.95 so I'll probably get another set next time I order something. I was also thinking of sawing a short piece of the right sized pipe in half lengthwise and then getting tabs welded to them. Should be bullet-proof.
96SilverRam
Nov 20, 2016 11:19 AM
96SilverRam
May 28, 2015 02:09 AM
96SilverRam
May 5, 2015 09:56 PM
twistedwedge
Jul 27, 2002 01:54 PM
