Alignment question Help.
Old Sep 18, 2006 | 12:05 AM
crazypurgatory's Avatar
Question Alignment question Help.
I just put the LS1 front brakes on my 1997 LT1 Camaro.
I am seeing some toe wear on the tires after driving it for a month or two.
My question is do I just need to adjust the Toe?
I see no other wear on the front tires other then toe wear.
I am 100% sure the LS1 spindles were not bent at all just because of how the car tracks down the road it pulls to the right and I could see the toe being out when I put the tie rod ends on to the spindles.
Thanks,
Chris G.
Old Sep 18, 2006 | 12:17 AM
blackztpi's Avatar
Re: Alignment question Help.
could be toe. make sure it is,. either toe or camber. toe you can do yourself in the driveway. just give it a few turns the one way on both sidea and try it
oldschool
Feb 9, 2016 09:21 PM
Deadbolt24
Jan 19, 2015 01:29 PM
Hurin
Dec 13, 2014 07:38 PM
Noenav
Dec 6, 2014 07:35 PM
Victory Racing
Apr 19, 2010 06:08 PM
