alignment after you lower?
Old May 20, 2006 | 02:00 PM
stingant0's Avatar
I was told that i need to have the car realigned becuase I put lowering springs on. Is this true?
I used eibach pro kit springs.
Old May 20, 2006 | 03:38 PM
Re: alignment after you lower?
Yes. And don't use the stock alignment specs. There are better specs for lowered cars. Check out the suggested specs in the "F-Body FAQ":
http://www.f-body.org/faq/4/4_5.htm
Old May 21, 2006 | 02:30 PM
stingant0's Avatar
Thanks!
Old May 24, 2006 | 11:29 AM
1quickTA's Avatar
I only lowered my front last fall. Do I still need an alignment?
Old May 24, 2006 | 02:06 PM
When you lower the front, it alters the caster and camber, and probably the toe-in. The upper and lower A-arms are different lengths and pivoting around axes that are not parallel. Do you have any evidence of irregular tire wear?
Old May 24, 2006 | 03:37 PM
TobyZ28's Avatar
Yes.
Old May 25, 2006 | 01:50 PM
1quickTA's Avatar
No, I don't see any evidence of irregular tire hear, but the tires have a lot of tread left so it would be harder to see. I guess I will add an alignment onto the "to-do" list. Thanks guys.
Old May 25, 2006 | 09:15 PM
jkucz31's Avatar
just rub the tread on the inner edge and see if it feels really choppy, what i want to know though is do i need a camber kit or can it just be alligned just like any other car
Old May 26, 2006 | 02:55 PM
AFAIK, they don't make camber kits for 4th gens.
n2oblkz
Oct 22, 2015 02:31 PM
n2oblkz
Oct 12, 2015 01:53 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
alliance12364
Sep 23, 2015 12:40 PM
