adjusting LCAs
Old Aug 10, 2007 | 01:17 PM
96LT1TX's Avatar
adjusting LCAs
I have the BMR Tubular LCA's and was wondering how to adjust them. I just got some 28" slicks and really wanted to know how to get these things to fit in there. With the 12 bolt in their for some reason the wheel is about 2" past center of the wheel well so it is hitting the rear fender now. Do I need to remove the LCA's to adjust them? If I do, what do I have to remove first before the LCAs?
thanks
Old Aug 10, 2007 | 02:40 PM
96LT1TX's Avatar
Nevermind, figured it out. Wow, 28"s are HUGE! haha, fit them on IROC 8" rims and they are 11.5" wide... cant wait for the track tomorrow!
Old Aug 10, 2007 | 05:09 PM
Keep an eye on the tires.... check them carefully after the first few runs.
They will "grow", and if they grow enough, they will be hitting the fenders, and cutting grooves in the tread..... or maybe causing a blowout. I had problems with my QTP 28x11.5-15's hitting the front edge of the wheel opening when trap speeds went over 125MPH. I moved the axle back 1/4" to cure it. Then with 28x10.5-15W ET Drags, they wouldn't even fit into the wheel wells untill I cut more then 1" off the leading edge of the bumper cover. We made a dyno pull to the equivalent of 130MPH, and the tires grew enough to hit the metal tip of the fender that is hidden behind the bumper cover. You don't want that to happen at 130+MPH.
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
95craz28
11
Sep 12, 2015 07:47 AM
