absinop light
Old Jul 2, 2005 | 11:17 AM
saltydog's Avatar
absinop light
my abs inop light comes on every now and then. ive checked the sensors behind the wheel and there good. whats the probelm
Old Jul 2, 2005 | 12:28 PM
Lyle A's Avatar
Re: absinop light
You need to have the ABS module scanned to see what's going on. Double check your third bake light lamps and connections also.
Old Jul 2, 2005 | 12:48 PM
saltydog's Avatar
Re: absinop light
third light is fine. i try to have it scanned the other day and the guy said for some reason it wont scan it. the scanner kept saying connect to dlc. whats the deal?
Old Jul 2, 2005 | 01:00 PM
Lyle A's Avatar
Re: absinop light
What year is your car?
Old Jul 2, 2005 | 01:08 PM
saltydog's Avatar
Re: absinop light
94 formula. the guy told me it should scan. he said to take to some one else and that it use a aldl hook up or something like that
Old Jul 2, 2005 | 01:17 PM
neversummer's Avatar
Re: absinop light
Mine did that too. It finally just stayed on. I eventually shelled out $1000 to the dealership to have a new ABS computer installed. Hope you find a cheaper solution than that.
Old Jul 2, 2005 | 01:25 PM
Lyle A's Avatar
Re: absinop light
Are you sure the guy scanning it was aware it is OBD1 and what kind of scanner did he use?
Old Jul 2, 2005 | 01:28 PM
saltydog's Avatar
Re: absinop light
im pretty sure it was a obd1 but not sure what brand it was. it was at advanced auto parts. autozone said they only do it free if the engine light is on.
Old Jul 2, 2005 | 01:57 PM
Cmr0z28's Avatar
Re: absinop light
Remove the ground stud by the positive terminal on the passenger side under the hood, sand all the connections, take a wire wheel to the stud itsef, and sand down the underlying paint to ensure a good ground. This is what fixed mine...
Old Jul 2, 2005 | 02:22 PM
saltydog's Avatar
Re: absinop light
what do u mean give me more detail.
Old Jul 2, 2005 | 02:52 PM
Lyle A's Avatar
Re: absinop light
There is a ground stud on the right fender well that a bunch of wires attach to. He means to take it apart and clean it real good. I'd post a pic but this site doesn't allow that in the threads.
Old Jul 2, 2005 | 02:55 PM
saltydog's Avatar
Re: absinop light
o ok ill give that a try
dluna333
15
Mar 13, 2015 12:30 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
