ABS system off ABS indicator off Brake indicator off but works
Old Mar 14, 2008 | 11:26 AM
RangerBob's Avatar
Unhappy ABS system off ABS indicator off Brake indicator off but works
I haven't posted in a long while. I have a 99Z28 that I had new rotors and pads put on in a local shop (Kuwait). I did a brake test at about 50 mph on dry pavement and all wheels locked up. I took it back and they scanned it and said that code C0050 (right?) rear sensor. I don't have traction control! They also said that I need to order (GM 10456115) which is the correct rear sensor for my vehicle. Do I have a ABS indicator lamp out (it doesn't light all all)? ABS codes should also light the brake indicator which works when I pull on the E-brake. I had the trans rebuilt last year and the mechanic (different one) had my car for a couple weeks when I was in Afghanistan. Could he have messed something up that would cause this? My cruise control hasn't works since the transmission was repaired.
I already ordered the sensor from the states, should I order any other parts?
Old Mar 14, 2008 | 11:28 AM
dangalla's Avatar
an abs problem will not usually light the red brake light, does the yellow abs light come on when you first turn the car on
Old Mar 14, 2008 | 11:41 AM
RangerBob's Avatar
ABS indicator will not light at all. Code c0050 should light both indicators.
Page 5-150 1999 Service Manual Vol 1 DTC C0050 RR Wheel Speed Circuit Malfunction
Action When the DTC sets
A malfunction DTC stores
the ABS/TCS disables (I don't have TCS)
The amber ABS/TCS indicator(s) turn on
The Red brake warning indicator turns on
DirtyDaveW
Dec 1, 2016 05:37 PM
squarehead
Jan 15, 2015 07:02 PM
ddr698
Jan 9, 2015 10:05 AM
Collector Car
Jan 5, 2015 10:58 AM
fpete1992
Dec 11, 2014 03:51 PM
