abs light on
Old Apr 17, 2012 | 08:59 AM
94Z28LS1toLT1's Avatar
abs light on
Hey guys how do i get the abs light off the dash my brakes and rotors are good no noises is there a sensor or relay that got messed up maybe
Old Apr 17, 2012 | 09:47 AM
mrmint69's Avatar
Re: abs light on
Has nothing to do with the brakes and rotors. Anti lock braking system appears to not be working. If you want it fixed, I would take to a shop and have them look at it for you. There could be some fuse or relay that might need replaced or something bigger is wrong.
Old Apr 17, 2012 | 11:57 AM
bt96ss's Avatar
Re: abs light on
Could also be a wheel sensor or the sensor on top of the rear end. Thats a problem Im working right now. My right front wheel sensor is bad.
Old Apr 17, 2012 | 02:20 PM
Re: abs light on
Abs is working great it has to be a sensor or fuse,or relay
Old Apr 17, 2012 | 04:47 PM
Re: abs light on
Doesn't the dash light say "ABS INOP"? Unless you have a short in the lamp circuit itself, the light is telling you there is a fault that has caused the electronic braking control module (EBCM) to turn off the ABS system.
1996LT1Z28
Apr 14, 2015 07:15 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
