ABS Inop light?
Old Aug 17, 2006 | 10:48 PM
Wicked 97TA's Avatar
ABS Inop light?
Ok I installed Pacesetter mid-length header on my '94 T/A. Before headers no ABS Inop light, now it's on. I took off my AIR pump while I was doing everything. When I start the car it dosen't come on until I get on the car a little bit. Can anyone help me start tracking down what it may be?
Old Aug 17, 2006 | 10:53 PM
torque6730's Avatar
Re: ABS Inop light?
Check to make sure your bake lights are all good. Mine came on and it turned out my third brake light bulbs were out.
Old Aug 17, 2006 | 11:28 PM
OBE1 95Z28's Avatar
Re: ABS Inop light?
The front ABS sensor harnesses run very close to the exhaust manifolds. Check that you have burned a wire or damaged them when installing the headers. Also make sure they're plugged in as there is a connector above 2 feet in from the wheels.
Old Aug 17, 2006 | 11:55 PM
streetwarrior96's Avatar
Re: ABS Inop light?
check the sensors at the disk's
Old Aug 19, 2006 | 08:05 AM
cehan's Avatar
Re: ABS Inop light?
Check for the connections at the ground cluster on the passenger fender well under the hood to be tight.
Old Aug 20, 2006 | 07:32 AM
Guest47904's Avatar
Guest
Re: ABS Inop light?
Plug wires are too close to the ABS unit. Happens all the time.
Old Aug 23, 2006 | 01:07 PM
Ivan1's Avatar
Re: ABS Inop light?
I would also check your fuses, I had a bad fuse when my "abs inop" light was on.
Old Aug 30, 2006 | 04:29 PM
Re: ABS Inop light?
I also took the AIR pump off at the time I was doing the header installation. I read somewhere that the AIR pump system has something to do with the ABS system. After I took all the hoses off from the AIR pump I had one very small hose just hanging there that ran over to a hook up mounted on her inner fenderwell. Does anyone know what that is and does it have anything to do with the ABS?
grabbem88
20
Dec 27, 2015 07:42 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
