ABS INOP due to dyno?
Old Mar 25, 2007 | 07:31 PM
nodnarb481's Avatar
I went to the dyno two days ago and here was what happened..
I give him the keys everything is check.. he pulls it in the shop.. i watch him hook everything up.. I watch him dyno it.. he pulls it out.. hands me the keys and says peace... I get in.. ABS INOP is on.. and its still on.
What do you think could have happened in that time?
Old Mar 25, 2007 | 07:32 PM
mdacton's Avatar
yep....tell them to reset it
Old Mar 25, 2007 | 07:52 PM
CamaroSS30thAnn's Avatar
My ABS INOPS light was on when i went on to the dyno to. When i came off the dyno it went off.
I think it just a dyno thing, at least in my case
Old Mar 25, 2007 | 09:07 PM
nodnarb481's Avatar
If i go to a shop and ask them to reset it do you think they will charge me something?
Old Mar 25, 2007 | 09:18 PM
JakeRobb's Avatar
Super Moderator
Mine came on during the dyno run, but I shut the car off and started it again and the light was gone. The ABS freaks out because it thinks something is wrong with the wheel speed sensors.
Old Mar 25, 2007 | 09:56 PM
OBE1 95Z28's Avatar
The ABS system monitors wheel movement; if the rear wheels are turning and the fronts aren't, like on the dyno , then the system thinks something is wrong. Of course, once you get off the dyno, the system should know things are back to normal. It's possible in your case that when they strapped down the car they damaged the cable/connection to the ABS in the top of the differential. Inspect the cable/connector.
Old Mar 26, 2007 | 11:31 AM
Projectz28's Avatar
Moderator
exactly... I've seen it happen several times before. they throw the strap over the axle on the driver side and strap the car down. Not knowing they threw the strap over the wiring harness that goes from the car to the rear axle housing (on 3 channel ABS cars), when they tightened the straps they rip the wires out. You probably just need a new harness.
Old Mar 26, 2007 | 12:54 PM
bombebomb's Avatar
I test drove a car like this once.so its not something rare.
Old Mar 26, 2007 | 05:06 PM
Projectz28's Avatar
Moderator
I pulled my car onto my trailer once. no light. pulled it off when I got home and I had an ABS light... whoops I ripped the harness out
Old Mar 26, 2007 | 06:33 PM
nodnarb481's Avatar
i just fixed it today.. i just went to the rear.. unplugged it.. pulled out the sensor.. looked at it.. and put it back in.. it just needed to see my eyes and know I wasnt messing around
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
fift5
11
Oct 1, 2015 10:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
