ABS INOP Diagnosis
Old 12-03-2004, 05:44 PM
willyc's Avatar
ABS INOP Diagnosis
Hello I have a 95 Z28 6speed. I am tring to get the trouble code but it keeps saying communication error. I am trying to access the codes throught the ABS program in my Snap-On scanner, Am I supposed to plug it in at the same location I do as when the Service engine soon light comes on? To read the engine codes I am using the trick where you run the two wires from the OBDl adapter to the connector and that works fine.
please help, will
willyc is offline
Old 12-06-2004, 09:00 PM
willyc's Avatar
Re: ABS INOP Diagnosis
Nobody can help me please anybody!!!
willyc is offline
Old 12-07-2004, 10:42 AM
CheshireCat's Avatar
What problem are you trying to diagnose? Did the ABS inop light come on? Is it on consistantly or intermitently? Are you having braking problems?
I don't have any info on using a scanner to get ABS trouble codes, but if you describe the problem a little more, I might be able to help.
Steve
CheshireCat is offline
Old 12-08-2004, 11:50 PM
willyc's Avatar
THe ABS INOP light is on all the time the brakes dont feel wierd or anything. I just wanted to know how to recieve the trouble codes for the ABS system.
thanks, will
willyc is offline
Old 12-09-2004, 03:40 PM
ZaneO's Avatar
Sounds like the ABS sensor has gone out (behind the hub).
ZaneO is offline
Old 12-10-2004, 01:34 AM
carlos64030's Avatar
Now you just have to determine which one.
carlos64030 is offline
KYWes
06-14-2022 06:52 AM
IndyZman
10-22-2015 02:17 PM
TGGodfrey
08-17-2015 08:43 PM
tnmotown
08-10-2015 11:52 PM
realistyc
07-28-2015 07:32 PM
Quick Reply: ABS INOP Diagnosis
