ABS Delete Specifics Please!!!
Old Aug 22, 2006 | 06:32 PM
jerrysta's Avatar
I have read a thousand threads today on deleting ABS and not one had the specific fittings listed. Now, as many guys as have done this there has to be someone that knows the proper size fittings to use???
My male end fittings all came out intact with none broken and I want to simply connect the fronts to a "T" fitting and the rear to a proportioning valve. I have read two different sizes for the front fittings one being 12mm and one being 3/16??? Which size are they on LT1 cars??
For the rears a couple guys also have used the Willwood valve wil-260-2220 (Summit part number). Will that match up with stock lines?
So from what I figure I would need either a 12mm or 3/16 all female end T for the front lines and the proportioning valve for the rear. Does that sound right?
Please help!!
Old Aug 26, 2006 | 12:56 AM
TW95Z's Avatar
Re: ABS Delete Specifics Please!!!
Here what I did. I put in the line lock instead of a tee, but it might help.
http://www.pharmacy.arizona.edu/staf.../NoABSTCS.html
Old Aug 27, 2006 | 06:35 PM
97WS6Pilot's Avatar
Please help!!
You'll have to work on your search techniques. Here is my write up.
http://web.camaross.com/forums/showt...delete+picture
All the stock fittings on the modulater are metric so you'll need to switch them over to standard in order to be able to hook it all up to the couplers. The two fittings on your master cylinder are metric and you'll need to reuse them. Also you can use a proportioning valve instead of the T I used. I didn't need to because my fronts locked up first.
IndyZman
Oct 22, 2015 02:17 PM
karpetcm
Sep 29, 2015 10:08 AM
4586
Sep 27, 2015 01:55 PM
KYWes
Sep 26, 2015 08:49 AM
95blkss
Sep 22, 2015 03:18 PM
