ABS computer
Old Jun 5, 2006 | 09:56 AM
agent z28's Avatar
Unhappy ABS computer
If the ABS computer will not communicate with the scanner, what should I look for? I can perform full diagnostics on the ECM, so I know the ALDL is not completely dead. The ABS computer terminals are clean and secure. How can I test continuity in the circuit to the ALDL? Can I trigger the ABS computer codes by jumping terminals on the ALDL to verify that the problem is with the scanner? My vehicle is a '93.
Old Jun 5, 2006 | 10:52 AM
MyShibbyZ28's Avatar
Re: ABS computer
Yes, you can put a paperclip between the two and it will flash the codes through the service engine light. Jump the top two right terminals.
http://shbox.com/1/dlc2.jpg
Old Jun 5, 2006 | 01:02 PM
rngilliland's Avatar
Re: ABS computer
It could be different on 93's but you can't get abs codes with any of the scanners sold for do it yourself use. The only way I could get my abs codes was to go to the dealer. If you have already tried a scanner I doubt shorting the pins and flashing the codes will give any more information.
Old Jun 5, 2006 | 01:03 PM
RE AND CHERYL's Avatar
Re: ABS computer
You will need a GM tech II scanner to retrieve the ABS codes.
DEALER
Old Jun 5, 2006 | 08:46 PM
agent z28's Avatar
Re: ABS computer
I'm using a Snap-On scanner, which should be able to pull ABS codes. I will see if I can borrow a Tech II. Can't say I'll be too pleased if it is the scanner in this case.
Old Jun 5, 2006 | 10:35 PM
Re: ABS computer
When I couldn't get the abs codes with a Tech II it turned out that the abs computer was the problem. I'm sure you know but the abs uses a seperate computer under the dash on the far left side.
IndyZman
Oct 22, 2015 02:17 PM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
fireside286
Sep 15, 2015 10:11 PM
