98 ls1 brake problem
Old Oct 25, 2010 | 07:55 PM
Rocks94z28's Avatar
My front rotors were warped so I put new ones on and left the old (70%) pads on, Both rotors seemed to have way to much resistance, I drove the car 3 miles and the rotors were extremely hot. I measured the new rotors and double checked the part numbers and they are the correct diameter, thickness and part number.
Both Front rotors feel like they are kinda stuck (they will turn with about 30 lbs of pressure) but there is no way both calipers would get stuck at the same time. I put the old rotors back on and the wheel turns fine without hardly any restriction.
What am I doing wrong? The rotors had too much restriction and got very very hot.
Thanks in ahead of time...
Old Oct 28, 2010 | 08:17 PM
FirstYrLS1Z's Avatar
frozen/difficult to reset caliper slider pins ?
Old Oct 28, 2010 | 08:19 PM
km9v's Avatar
Grease the caliper pins. I would have used new pads w/ new rotors.
Old Oct 28, 2010 | 09:17 PM
n2ceptor's Avatar
Your old pads formed to the old rotors... Old rotors, new pads is OK, but not the other way around...
Old Oct 28, 2010 | 11:44 PM
Rocks94z28's Avatar
i bought new pads, I'll put them on tomorrow, thanks for the help/ideas
Old Oct 29, 2010 | 08:16 PM
95TA04GOAT's Avatar
I have never had a problem replacing or machining rotors while keeping the same pads. Did you clean the rotor after you took it out of the box? They put a coating on it that's intended to prevent it from rusting. If you install them without first removing the coating it can cause some issues, possibly like your describing. If you didn't clean the rotors i would remove them and clean it up with some brake clean. Then use some sand paper, maybe 100 grit or so, and scuff up the rotor surface. Also sand the pads down just a bit against a flat surface to get the glaze off them. Then reinstall making sure to lubricate the slides with the appropriate grease.
dluna333
15
Mar 13, 2015 12:30 PM
Brake_L8
Jan 20, 2015 09:44 AM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
