96 Z28 - (6) rubber brake lines ??
Old May 25, 2010 | 09:22 AM
vp1's Avatar
vp1
I just purchased a '96 Z28 for a track car at Watking Glen. I want to swap out the rubber brake lines for SS but ..........
...... there are (6) rubber hoses and all the SS kits I found show either (4) or (5) SS lines, but no (6) line kit.
Any suggestions as to what I could buy?
Old May 25, 2010 | 09:28 AM
97FormulaWS-6's Avatar
6 rubber lines?!?!? where?
1 each front wheel, 1 each rear wheel, and 1 between the chassis and rear axle.
Old May 25, 2010 | 09:35 AM
vp1's Avatar
vp1
There are two (2) steel lines coming to the rearend from the front of the car (not just one). Each of these steel lines ends before the rearend and then connect with rubber hoses to two steel lines on the rear itself. The two lines independently feed the RR and LR brake calipers all the way from the front.
Old May 25, 2010 | 11:51 AM
vp1's Avatar
vp1
I am assuming the dual brake lines from the front have something to do with either the traction control or anti-lock.
Old May 25, 2010 | 01:16 PM
hotpart's Avatar
Former Vendor
You have a car with traction which uses 6 hoses. This is what you need below.
http://www.hotpart.com/shop/index.ph...ct_detail&p=39
Old May 26, 2010 | 08:08 AM
my bad... forgot about the 4ch ABS/Traction control cars.
Old May 26, 2010 | 01:06 PM
vp1's Avatar
vp1
Yes --- Thank You!!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
