94 Front LCA poly insert ?'s
Well cant afford new front lca's so im going to install poly inserts and hopefully buy new next year... ive searched and couldnt really find anything...
just curious if anyone has ever done this before and if they have any advice for me...or if you could point me in the right direction..both my lower bushings are bad where they go into the cradle...but ill be changing them all.thanks
If your going to be replacing the bushings why bother replacing the complete control arm next year? I've never replaced those bushings on an F-body but they should be pretty simple once you get the arm out. Having access to a press will help a lot.
you going to be replacing the upper and lower control arm bushings with poly bushings? i used the prothane bushings when i rebuilt the front end last year. once you have the control arms off you have to burn out the old bushings with a torch and scrape them clean with solvent or something. Lube up all the poly bushings, the uppers you kinda have to press in with the sleeves installed (i used a 2-4 and hammer) and the lowers just kinda fit in place where the stock bushings use to be. it took about a day for me cause i did one side at a time and replaced the upper balljoints, shocks, springs, and tie rod ends.
carguyshu
Jan 22, 2017 11:19 AM
96SilverRam
Nov 20, 2016 11:19 AM
Black Sunshine/ 00SS
Jul 17, 2002 08:41 PM
