93-97 vs. 98-02 brake information
Old Mar 26, 2007 | 08:12 AM
shelby987's Avatar
I have a g-body I am working on building right now, and I am having some difficulty tracking down some information, I was hoping someone here could point me in the right direction.
I am doing a brake swap on the front of the car using B-body spindles and 86-92 12" 1LE rotors. Will the calipers from 93-97 or 98-02 fit on these rotors? I can't seem to find an answer as to the specs. of the factory calipers for these ranges (width/diameter of stock brakes, and 1 or 2 piston design). I am pretty sure 98-02 have 12" rotors, but not sure about 93-97.
Also, looking up upgrade the 8.5" 10bolt to disc brakes as well, and with a little work I know an F-bodies brakes will go on......what is the difference if any between 93-97 and 98-02 rear brakes?
Old Mar 26, 2007 | 11:52 AM
MyShibbyZ28's Avatar
98-02 brakes are roughly an inch bigger on all 4 wheels compared to 93-97. I believe 98-02 front calipers are dual piston vs 93-97 only being one.
Old Mar 26, 2007 | 07:55 PM
Greed4Speed's Avatar
98-02 rotors are 12" (11.9"). The calipers are 2 piston. The outside dimensions are the same as the C5 calipers except the casting process was different the C5 has longer ribs and the C6 pistons are smaller.
Why am I telling you all this? Because if you can fit the LS1 calipers then you can fit the C5 calipers and both work with the C5 13" (12.9") rotors.
Rod Bender
May 16, 2015 02:16 PM
NewsBot
Apr 9, 2015 07:10 AM
LT14LIFE
Feb 9, 2015 09:35 PM
ddr698
Jan 9, 2015 10:05 AM
