32mm 1LE Sway Bar Bushings/End Links
Old Oct 11, 2005 | 07:55 PM
Bersaglieri's Avatar
I am thinking about buying a 32mm 1LE sway bar and was wondering where do I buy new bushings and end links? I read that GM sells some, but are they poly or rubber? Thanks.
-Dustin-
Old Oct 12, 2005 | 06:19 AM
Z28barnett's Avatar
Re: 32mm 1LE Sway Bar Bushings/End Links
1LE Stabilizer Bar Endlinks (GM p/n 10221779) $7.05 (Need two)
1LE Front 32 mm Stabilizer Bar Insulator (GM p/n 10288551) $7.66 (Need two)
The bar insulators are rubber, the end links are black with white plastic isolators.
Might be poly, but they work and they fit. In general rubber is better than poly and GM actualy tests their parts.
Z28
Old Oct 12, 2005 | 06:45 AM
I read this in Camarocracy's thread about GM's stuff, and SLP is selling bushings for $3.50 online. I am going to get the SLP/GM ones if nothing turns up at Summit when I stop after class today. I have $20 in Summit bucks to spend. Thanks.
-Dustin-
Old Oct 13, 2005 | 12:33 PM
Mr. Merk's Avatar
SLP will rape you one shipping charges, they are insane
Old Oct 13, 2005 | 12:54 PM
Yea, I saw that buying the duro ones from SLP would cost around 14.XX after shipping where as I can stop at Summit, like I did yesterday and get them for $12 and they are poly. Thanks guys, for future information, Summit has both items you'd need.
-Dustin-
96SilverRam
Nov 20, 2016 11:19 AM
HarleyZ28
Oct 5, 2015 06:23 AM
Alien
Jun 27, 2015 01:13 PM
8T8IROC
Mar 26, 2015 09:02 PM
