3 mods, money for 2. lcas, torque arm, rlb
Old Mar 2, 2006 | 02:04 AM
The Anti Riced's Avatar
Multiple track runs have proved it, stock suspension needs help. I've made a habit of running low, low 13s on my nittos. When I try to launch hard they still grip great but wheelhop is insane.I'm looking into 3 mods but can only really buy 2 right now. Lower control arms, Relocation brackets, and Torque arm. Which 2 should I buy to reduce this wheelhop and grab some 12s. thanx Nick
Old Mar 2, 2006 | 06:47 AM
Honda Hunter's Avatar
Re: 3 mods, money for 2. lcas, torque arm, rlb
Injuneer says he knows people in the 10's with the stock tq arm bar. Thats why I went with lca's, phb, and sfc's. I have some comp eng rear shocks coming in the mail and I plan on going with qa1 drag r shocks and 175lbs springs up front. After reading alot of different opinions I feel this should be a great combo. later like next month or so ill spring for the tq arm and drag anti roll bar to complete my setup.
Old Mar 2, 2006 | 07:31 AM
teke184's Avatar
i agree...the stock TA is reasonably stout...by far the stock LCAs are worse.
i would do the lca, brackets and then spend $15 on a poly torque arm mount. the mount is where the most flex is on the torque arm. and it's a cheap and easy upgrade to firm up the setup.
i have the setup on my car now...never had wheelhop since it was installed
Old Mar 2, 2006 | 07:33 AM
What exactly do you have as far as suspension and what type of 60's are you seeing?
Old Mar 2, 2006 | 02:07 PM
My suspension mods are kyb shocks, Eibach pro-kit springs, Energy suspension torque arm bushing, poly trans mount, complete poly bushing kit. I've heard with a lowered car I should have relocation brackets.
Old Mar 2, 2006 | 02:14 PM
My 60 foots are usualy 2.1s, I pulled a 2.0 but sorta spun second too much. BTW: Honda Hunter, way to make a cool mustang.
Old Mar 2, 2006 | 02:17 PM
Old Mar 2, 2006 | 04:41 PM
2000GTP's Avatar
The relocation brackets and lcas will be most beneficial in reducing wheelhop, not to mention that both will run you under 200 bucks where as a good torque arm will run in the 300-400 range.
canbaufo
May 5, 2015 03:43 PM
KYWes
Apr 24, 2015 09:17 AM
Jason Short
Jan 19, 2015 06:34 PM
