1le shocks springs?
Old Dec 19, 2006 | 01:38 AM
ajlew9428's Avatar
1le shocks springs?
is there a difference between 1le shocks, springs, and z28 shocks, springs for 93-02? I know the ss has different valving, or something. Which is best all around of these 3 it 1le even has a difference?
Old Dec 19, 2006 | 08:27 AM
http://www.f-body.org/faq/4/4_1.htm
Old Dec 19, 2006 | 09:52 AM
ajlew9428's Avatar
thanks. Do you think those springs and shocks would be a good upgrade for primarily street? Where can I get them?
Old Dec 19, 2006 | 11:46 AM
Not sure what is even available any more. I would get some advice from Sam Strano on here (or you can call him). He can set you up with something to meet your goals and you would probably be much happier.
Old Dec 19, 2006 | 12:17 PM
Sam Strano's Avatar
There are 3 different versions of "1LE" for the 4th gen. Each has different spring, bar, and shock combinations. But, the internet being what it is that information is largely not known or just ignored.....
The better question is what you are wanting to do different with the car. 1LE is not the end all by any means. My car is a standard Z28 that I bought to autocross against 1LE's which are also legal. I've driven both. I prefer a Z28 with some changes over a 1LE personally (I even ordered my car) for F-Stock autox where you can only change the shocks and the front bar. Once you get away from those rules than having any 1LE parts is really not necessary, the only "1LE" thing I actually use are the rear control arm bushings which we get from Moog.
HarleyZ28
Oct 5, 2015 06:23 AM
Fastbird93
Jun 3, 2015 05:56 AM
KYWes
May 22, 2015 08:48 PM
BLK1997Z28
May 1, 2015 12:23 PM
RichJ
Sep 14, 2002 09:37 AM
