Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
Is Your Rearend Hurtin'? Time For A Strange 12 Bolt or Dana S60!
Old Sep 21, 2007 | 01:12 PM
tbyrne's Avatar
The stock 10 bolt is the weak link in the Camaro/Firebird drivetain. We can help you take care of that!
Strange 12 Bolt -
Gear ratios available are 3.42, 3.73, 3.90 and 4.10. The 3.90s will be noisy so Strange doesn't promote this one. This rearend now comes standard with the Super Strength posi. Each one is shipped ready to be installed. You will just need to swap the brakes from your current rear. Shipping is freight collect for this product so you will need to take care of that with the driver when he delivers.
PRG210-PRGOP8 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Super Strength posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor at the axles - usually for traction control cars)
PRG210-PRGOP-14 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Super Strength posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor on the top of the pumpkin)
PRG230 Strange Race Setup w/Spool
(Not offered w/o Spool)
(Note: LS1 customers need to send in backing plates & caliper mounts if using stock brakes-ABS & TC will not work)
R5206 Upgrade to aluminum support cover (not available for the Dana S60) $114.99
gmbbp-tc Options: You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will either need to send in your backing plates & reluctor rings or purchase them separately. (Use this option if your car has traction control) $279.99
gmbbp-notc Options: You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will either need to send in your backing plates & reluctor rings or purchase them separately. (Use this option if the car does not have traction control but does have ABS) $229.99
OPRG13 Reluctor Ring Set $69.99
Dana S60 -
Dana S60 features -
35 spline axles
HD Posi
Chrome Cover
3 or 4 channel ABS
You will need to send your brake backing plates in just before the rear is built so they can be built into the rear. We can sell a new set to you separate. The stock driveshaft will need to be shortened by 1.625".
The following gear ratios are available - 3.54, 3.73, 4.10, 4.30, 4.56, 4.88, 5.87.
The weight difference between Dana 60 and 12 bolt is 20-25 lbs, the Dana is heavier. Dana rear is fully assembled with posi weights around 215 lbs and 12 bolt is around 189 lbs (weight with brakes). The weight difference between 12 bolt and 9" is about 12-15 lbs the 12 bolt being lighter.
Ring gear sizes:
12 bolts ring gear only 8.875 OD
9 ring gear is is 9" OD
Dana has ring gear of 9.75 OD which is alot stronger than 12 bolt & 9".
The standard Dana gear (not Pro) can withstand close to 1200 RWHP.
The True-Track is posi is standard along with Power-Lock. These are good for about 600rwhp. The Dana's posi is alot stronger than a 12 bolt and the 9". This is because the Dana Posi's are 35 spline, 12 bolt is 33 spline and the 9" is a 33 spline.
PRSF05 Strange Dana S60 (will need to purchase a new driveshaft or send yours in to be balanced with the new rearend)
Options
True-Track Upgrade to True-Track Posi For S60 $79.99
Detroit Upgrade to Detroit Locker Posi For S60 $79.99
Driveshafts for Dana S60
U1699 Strange U1699 driveshaft 3"x.083" DOM chrome moly driveshaft with H.D. U-joints
U1700 Strange U1700 driveshaft 3"x.083" Seamless chrome moly driveshaft with High Imp. U-Joints
U1702 Strange U1702driveshaft 3"x.083" Seamless DOM chrome moly driveshaft with H.D. U-joints
Pricing for the driveshafts and rearends is much lower than we should advertise so we have to ask that you give us a call at 1-877-482-9763 or e-mail tbyrne@tbyrne.com to receive a quote. It will definately be worth it!
Have a great day!
TBYRNE MOTORSPORTS LLC
ORDER LINE - 1-877-4-TBYRNE
E-MAIL - tbyrne@tbyrne.com
CHECK OUR WEBSITE FOR WEEKLY SPECIALS! INSTALLATION SPECIALS AVAILABLE!
Old Sep 21, 2007 | 01:30 PM
JasonD's Avatar
Admin Emeritus
Red face
Not typically...but that's getting a bit personal, don't ya think, Tom?
Old Sep 22, 2007 | 10:14 AM
tbyrne's Avatar
Lol!!!
Old Oct 4, 2007 | 01:37 PM
tbyrne's Avatar
Also, we are able to offer a slightly greater discount for orders that are placed by Friday, October 19th. These are probably the lowest price that we've had for these in years! Don't miss out!!!
Old Oct 4, 2007 | 08:02 PM
GRNcamaro's Avatar
hey can you shot me a price for the sale and what u sell them for regularly for a 12 bolt with posi and 4:10 gearing. im putting it in a 95.
Old Oct 5, 2007 | 08:06 AM
tbyrne's Avatar
Sure! Just give us a call or e-mail for pricing!
All of last night's requests will have a reply shortly.
Old Oct 10, 2007 | 01:31 PM
tbyrne's Avatar
Offer ends next Friday!
Old Oct 10, 2007 | 07:45 PM
wrd1972's Avatar
Please PM me a price for the S12-bolt for a 95 Z28 with 98+ rear 12" brakes. Zip code 40511.
Old Oct 12, 2007 | 07:34 AM
tbyrne's Avatar
Please refer to posts 1 and 6.
Old Oct 18, 2007 | 09:01 AM
tbyrne's Avatar
Last call!
Old Oct 19, 2007 | 08:40 AM
tbyrne's Avatar
Today is the last day for this one!
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
87Aerocoupe
Jan 10, 2015 07:27 PM
ddr698
Jan 9, 2015 10:05 AM
