Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
Strange 12 Bolt/Dana S60 Rearend Group Purchase
Old Jan 9, 2007 | 07:40 PM
tbyrne's Avatar
The stock 10 bolt doesn't stand up to alot of horsepower. Especially when you bolt on sticky tires for the track. We've put together a group purchase to save you some money and to beat the Spring rush for these!
12 Bolt -
Gear ratios available are 3.42, 3.73, 3.90 and 4.10. The 3.90s will be noisy so Strange doesn't promote this one. This rearend now comes standard with the Super Strength posi. Each one is shipped ready to be installed. You will just need to swap the brakes from your current rear. Shipping is freight collect for this product so you will need to take care of that with the driver when he delivers.
GP prices -
PRG210-PRGOP8 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Super Strength posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor at the axles - usually for traction control cars) $2219.99
PRG210-PRGOP-14 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Super Strength posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor on the top of the pumpkin) $2219.99
R5206 Upgrade to aluminum support cover $114.99
gmbbp Options: You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will need to send in your backing plates along with your axles so Strange can use the reluctor rings. $229.99
gmbbpcore Options: If you can't have any vehicle downtime we can charge you $229.99 for a set of backing plates and send them to Strange to be build into your rear. After your 12 bolt is installed you'd send your stock backing plates to us and we'd credit you $175.00. This option is only available if your car does not have traction control or the ABS at the axles. The backing plates are only required for 1998+ cars.. $229.99
Dana S60 -
Dana S60 features -
35 spline axles
HD Posi
Chrome Cover
3 or 4 channel ABS
You will need to send your brake backing plates in just before the rear is built so they can be built into the rear. We can sell a new set to you separate. The stock driveshaft will need to be shortened by 1.625".
The following gear ratios are available - 3.54, 3.73, 4.10, 4.30, 4.56, 4.88, 5.87.
The weight difference between Dana 60 and 12 bolt is 20-25 lbs, the Dana is heavier. Dana rear is fully assembled with posi weights around 215 lbs and 12 bolt is around 189 lbs (weight with brakes). The weight difference between 12 bolt and 9" is about 12-15 lbs the 12 bolt being lighter.
Ring gear sizes:
12 bolts ring gear only 8.875 OD
9 ring gear is is 9" OD
Dana has ring gear of 9.75 OD which is alot stronger than 12 bolt & 9".
The standard Dana gear (not Pro) can withstand close to 1200 RWHP.
The True-Track is posi is standard along with Power-Lock. These are good for about 600rwhp. The Dana's posi is alot stronger than a 12 bolt and the 9". This is because the Dana Posi's are 35 spline, 12 bolt is 33 spline and the 9" is a 33 spline.
GP prices -
PRSF05 Strange Dana S60 $2049.99
Driveshafts for Dana S60
U1699 Strange U1699 driveshaft 3"x.083" DOM chrome moly driveshaft with H.D. U-joints $209.99
U1700 Strange U1700 driveshaft 3"x.083" Seamless chrome moly driveshaft with High Imp. U-Joints $329.99
U1702 Strange U1702driveshaft 3"x.083" Seamless DOM chrome moly driveshaft with H.D. U-joints $289.99
5 or more orders are required by Tuesday, January 23rd for this to go through. We will start ordering these when we have 5 orders in so it will be good to order early! This GP covers all rears that Strange produces so let us know if you need a rearend for a vehicle that isn't listed here.
Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763.
Have a good day!
TBYRNE MOTORSPORTS LLC
ORDER LINE - 1-877-4-TBYRNE
E-MAIL - tbyrne@tbyrne.com
CHECK OUR WEBSITE FOR WEEKLY SPECIALS and PRICE MATCH PLUS POLICY!
DISCOUNTS AVAILABLE FOR SUPERCHARGERS, TURBOS AND NITROUS KITS. PLEASE CALL FOR PRICING!
Old Jan 9, 2007 | 08:20 PM
ws6transam's Avatar
Oh man, WHATTA DEAL! I hope you sell a thousand of them!
Old Jan 10, 2007 | 12:09 AM
posenheimer's Avatar
Exclamation
Count me in please... Dana s60 for 97 camaro z28 and the 320+ driveshaft 3:73 gears... cash ready within the next week. Can I get the brake backings added on too. and PM me price total... thanks a million!
Old Jan 10, 2007 | 08:23 AM
camarolt4ss's Avatar
so let me ask you guys.... for a car with about 750rwhp which is going to be a better rear end???
Old Jan 10, 2007 | 11:09 AM
cjmatt's Avatar
yeah ill most likely take a strange 60 as well. do the torque arm bolts go all the way through the housing like the mosers on the dana 60s? also, do you offer a posi for more than 600 rwhp?
Old Jan 11, 2007 | 09:29 AM
cjmatt's Avatar
is anyone getting in on this group purchase?
Old Jan 11, 2007 | 10:10 AM
if someone answers me, id be interested
Old Jan 11, 2007 | 10:34 AM
always faster's Avatar
You need to call them.They dont come on the board really often.There service is great.I ve bought my 12 bolts from them
Old Jan 11, 2007 | 10:36 AM
well then ill have to do that
Old Jan 11, 2007 | 10:42 AM
cjmatt's Avatar
the dana 60 is alot stronger than a 12 bolt, so itll probably be better for a 750 rwhp car
Old Jan 11, 2007 | 02:23 PM
BassProCamaro97's Avatar
Whats the suggest HP rating on the 12 bolt as compared to the S60. I have seen some saying the 12 is good up to 1000HP.
Anybody have any say on the ratings numbers?
~Jim~
Old Jan 11, 2007 | 02:49 PM
~Jim~
From what i ve heard and also read the stock 12 bolts posi(the 9 clutchs) begin to suffer at 700hp and the HD posi(14 clutchs) can reach the 1000hp.
Old Jan 11, 2007 | 06:45 PM
tbyrne's Avatar
A few have requested shipping quotes. These rears are shipped freight collect from Strange so we aren't able to get a firm quote. Rates change with the price of fuel so it wouldn't be the same when they ship anyway. A rough estimate is usually in the $125. - $250. range. The trucking co would call a few days ahead to set up the delivery and prove the shipping amount due.
The S60 was released early last year. A number of customers have gone with this for high horspower applications (don't have a firm max number yet). The Strange 12 bolt has been fine behind motors producing 500-600hp.
We already have 2 orders in for this one!
Old Jan 11, 2007 | 07:00 PM
cjmatt's Avatar
put me down for a dana 60...and can you explain the differences in the driveshafts as far as power handling
Old Jan 11, 2007 | 09:54 PM
Am I one of those two orders in on this one???
