Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
Sieman Deka High Impedence Injectors $549.95
Old Feb 21, 2004 | 05:55 PM
New Era's Avatar
These are the ultimate in compact fuel injectors. Its small size and high flow rate makes it the perfect choice for challenging EFI applications. The injector flows 60 lbs/hr at 3 BAR (43.5 PSI); and up to 85 lbs/hr at 87 PSI! Adding to the flexibility of application, these units are high-impedance; making them compatible with most ECUs, while delivering the most flow available in a High-Impedance injector.
These injectors are the perfect upgrade for stock manifold & rail assemblies; replacing standard 75 mm packaged injectors. Also recommended for use in custom manifolds where optimum injector targeting requires more length.
Engine performance and running quality is enhanced through the optimized spray pattern of all Sieman Deka fuel injectors. Unlike competitors “pencil stream” high flow injectors; Sieman Deka High Flow injectors utilize a multi-orifice tip providing a true 30 degree spray pattern for improved mixture preparation. This results in lower BSFC and better idle quality than many injectors of less flow.
ONLY $549.99
Online orders only www.neweraperformanceparts.com .
Thanks ,
Mike
sales@neweraperformanceparts.com
onefastgta
Mar 19, 2015 10:09 AM
IDOXLR8
Aug 6, 2002 12:30 PM
moneyshotz
Jul 27, 2002 06:16 AM
