Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
Replace your damaged catalytic converter with a new one from iD Select + Promo
Old Apr 28, 2021 | 07:16 AM
CARiD's Avatar
Former Vendor
The catalytic converter plays a crucial role in your car's exhaust system. If your car has failed its emission test, you might need a replacement catalytic converter. iD Select has got you covered with its wide range of first-rate products made from top-grade materials on modern, high-precision equipment, which allows the brand to maintain the highest standards.
To pass an exhaust emissions test, the converter must have the exact configuration and capacity as specified by the OEM, and the iD Select product meets these requirements. Designed to replace your worn-out or malfunctioning components, they’ll provide the same fit, form, and function. With its corrosion-resistant, stainless steel construction, you can rest assured that it will serve you for years to come.
Shop now and save up to 34% on iD Select Products at CARiD. This offer expires on June 16, 2021. Prices are already reduced.
iD Select® - ECO III Direct Fit Catalytic Converter
https://www.carid.com/id-select/eco-...converter.html
iD Select® - ECO II Universal Fit Catalytic Converter
iD Select® - Standard Exhaust Manifold with Integrated Catalytic Converter
https://www.carid.com/id-select/stan...converter.html
View the full list of iD Select Products: https://www.carid.com/id-select/
Bersaglieri
New England Area
Jul 31, 2007 07:35 PM
Mike Comp T/A #57
Apr 21, 2006 08:40 PM
ringo234
3rd Gen / L98 Engine Tech
Jan 30, 2006 04:50 PM
wrd1972
Nov 28, 2005 09:22 PM
BlackLT1_TX
Mar 21, 2004 03:17 PM
