Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
lets start a gp on Centerforce clutches
Old Apr 8, 2006 | 01:17 PM
detroit1994z28's Avatar
Need a new clutch for my 94 z28. Would like to upgrade to a centerforce dual fricition. Anyone here want to try and start one up - Mike
Old Apr 8, 2006 | 08:39 PM
Randy Molkentine's Avatar
Re: lets start a gp on Centerforce clutches
centerforce is garbage. spec or mcleod
Old Apr 10, 2006 | 01:13 PM
Z94SLEEPER's Avatar
Cool Re: lets start a gp on Centerforce clutches
I can't say anything about Spec or Mcleod however I have and still have the Centerforce dual friction and have had zero problems. It's been a great clutch and the next will most likely be the same when this one finally wears out. I've had this one for 4 years and still going strong....
Eric
Old Apr 10, 2006 | 08:18 PM
I've had 3. The first would not go into reverse. Then I got a redesigned replacement which was supposed to fix the reverse issue...same issue. 3rd I sold before I installed it. Do a search on centerforce problems.
Old Apr 10, 2006 | 08:36 PM
I did a ton of research on these clutches. I found the street twin to be the best clutch -- But that's a little to much then what I want to spend. I been reading allot of problems with spec. Many only get 3k or so miles out of them also they happen to be exploding in some cars on the ls1tech site. Centerforce is defently the clutch I'm going with.
Old Apr 10, 2006 | 08:40 PM
Hey whatever you go with is fine with me. I am just stating the problems that I have had, as well as alot of friends. Maybe they have been re redesigned or somthing but I had nothing but problems with them. I have a street twin now, and with all the reinstalling it would have been cheaper from the get go. I have also heard alot of negatives about the spec, but from the people I know who have them they seem to have less issues then CF.
Old Apr 10, 2006 | 08:42 PM
95 Z/28 LT1's Avatar
Super Moderator
Centerforce clutches for an LT1 are junk, stay away!
Old Apr 10, 2006 | 08:46 PM
Don't listen to this guy either..hes only got 6000 posts and is a moderator
Old Apr 10, 2006 | 08:48 PM
I guess it's a hit/miss on every clutch out there. Some have good - some have bad experinces with the same clutch
Old Apr 10, 2006 | 08:51 PM
I don't know about this....but I can say at the time I was having issues with the CF the first and second times it was common knowledge that tons of people were having problems with them in the LT1 crowd.
Old Apr 11, 2006 | 12:44 PM
Z94SLEEPER's Avatar
Well, as stated above mine has been flawless since the day I had it put in. I may have just recieved a good one, I'm not sure however it's still strong enough to break some new gears I had just put in the car last Nov. Just now able to replace the gears, next will most likely be a 12 bolt and suspension work....
Eric
Old Apr 17, 2006 | 11:30 PM
JeffK95Z's Avatar
I have a center force dual friction clutch as well... it was installed back in 99, so i've had for close to 7 years now, and have put roughly 50-60,000 km's on it.
When i got it, everyone raved about them. a few years after, everyone hated them. Not sure what happened, but it really seemed like the design?/quality went down hill.
I've had little to no problems with mine and it still grabs perfect with no slipping what so ever!!
good luck with your choice!
jeff
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
HectorM52
Jan 30, 2015 11:08 PM
slothgrant
Aug 22, 2002 03:01 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
