Granatelli Adjustable High Flow MAF for 85-92 F-Bodies special!!
If you have a highly modified 1985-1992 TPI Camaro, Firebird, Corvette, then this is the sensor for you. Our unit is the only mass airflow sensor that features FULLY ADJUSTABLE CALIBRATION, so high lift cams, big valves and larger intakes are no longer a tuning problem for performance enthusiasts. The sensor provides up to 30% more airflow than the standard OEM unit, and you don’t have to tear out the screen! The Granatelli Motor Sports Adjustable Mass Airflow Sensors come equipped with a calibration screw built right in. Engine running too rich or too lean? No problem!! Just whip out a screwdriver, give the calibration screw a twist and WHAM!!, problem solved. No other mass airflow sensor available gives you this much control. Installation occurs in 10-15 minutes using basic hand tools. Each system is backed by a limited 90-day warranty.
Only $299.95 Introductory price at www.neweraperformanceparts.com !!!!!
Thanks ,
Mike
sales@neweraperformanceparts.com
Mike
Thanks ,
Mike
Mike
Honestly, it is cheaper to convert over to SD. Thats the only reason why I did in my 89 IROC.
Still tho that is cool as hell that someone came out with this. I know of a few people that I've seen over the years that would benefit from this.
Kat
Kat
Kat
Kat
Still a cool product though.
Originally posted by PhantomTA
im surprised more third gen guys arent in here talking about this?
How long did it take for the MAF Translator to come out for the LT1 cars? Not this long
Originally posted by AutoRoc
They're roughly 10-15 years late with the product.
Its no wonder nobody wants to support thirdgens anymore. Someone comes up with a new product and you guys bash him for it.
Although, I have to ask, does this work for '85 TPI's? They have a different type of MAF and a different computer than the 86-89 stuff. Also, the 90-92 TPI's do not use a MAF sensor, so this product wont work for them.
But, thank you for supporting our thirdgens with this!!!
According to Granatelli Motorsports , yes , it will work on the 85 TPI 305/350 .
Thanks,
Mike
Thanks,
Mike
I am unsure what the inner diameter is , the outer diameters are the same as stock and will work with the stock couplers .
Thanks ,
Mike
Thanks ,
Mike
alex5366
Mar 8, 2015 11:32 AM
jeff94z28
Sep 11, 2002 02:01 PM
