Get superior braking performance and looks with Chrome Brakes Rotors!
Are you looking to replace your factory rotors? Restore your Chevy Camaro's braking power and add a custom touch to it with a set of brake rotors from Chrome Brakes! This manufacturer offers premium-quality drilled and slotted brake rotors, available in a wide range of colors.
Being produced from the highest quality G3000 grade of "gray" iron with graphite microstructure, they provide the superior level of cooling needed for high-performance street driving and drifting. Sized to match OEM dimensions, Chrome Brake rotors come brand-new ready for installation with no cutting or turning required.
Chrome Brakes® - Drilled and Slotted Brake Rotors
https://www.carid.com/chrome-brakes/...ed-rotors.html
Features:
View the full list of Chrome Brakes Pads & Rotors at CARiD: https://www.carid.com/chrome-brakes/
If you want superior brake pads and rotors for high-performance driving that exceed OEM quality standards, Chrome Brakes will be your best bet!
Features:
- Sized to match OEM dimensions while providing superior braking performance and better looks
- Produced from the highest quality G3000 grade of "gray" iron with graphite microstructure
- Rotors have high thermal conductivity and are extremely resistant to temperature buildup
- Lower operating temperatures reduce rotor warp, fluid boiling, and hot spotting
- Rotors are slotted and drilled for better venting of heat, water, brake dust, and gasses
- Rotors are machined to a fine, consistent weight balance to provide the smoothest brake applications
- Pyrolytic Chromium Carbide (PCC) color coatings provide a higher level of resistance to corrosion and temperature buildup on non-contact areas than zinc or paints
- 1 year / 36,000 mile manufacturer warranty is effective until rotors reach minimum thickness due to normal wear
97formulakid
08-04-2007 04:11 PM
POWRFUL
08-24-2006 09:44 PM
