what mods should i go with???
hey guys. i'm gonna have about 3,000 rolling in soon so I need to know what I should do. i have many thoughts which need some guidance. please help me out!!! here's the possibilities:
1)sell my 350 lt1 and buy a 383. the 383 will cost 2295.00 WHAT ELSE WILL I NEED TO DROP INTO MY 93' Z-28? PRICES?
2)keep my 350 lt1 and do mods in which order??? which cam should i go with, which headers (jet hot or dynatech lt's???)
1)heads, cc306 cam w/1.6rr's,headers w/true dual spintechs,and 3.73 gears
2)3.73 gears, headers with true duals, heads and a cam
3)headers with true duals, 3.73 gears, heads and a cam
4)headers with true duals, heads and a cam, 3.73 gears.
-OR- should i go with completely different mods or these in a different order? please help me out.
I do NOT want to do a blower or nitrous yet.
-Daniel
-Daniel
for about 3k...
Callies dragonslayer crank (3.75", 5.7/6.0 rod) - ~900
SRP high compression forged pistons (.030") - ~425
eagle forged rods - ~400
JE pro seal rings - ~100
ARP main studs, and head stud kits - 225
machine work and assembly - 550
gasket set - ~200
clevite 77 main/rod bearings - 160
LT4 HD timing chain set - ~250
36# injectors - ~200
there's your 383, and a pretty damn sturdy one at that if you ever decide to go spray! might wanna toss a cam into that, and do the heads while your at it, thats about another 1500...
the bottom end alone, i would think to make in the 350 range, and very nice torque.
if i had my chance to do my setup over, that would be it, (3.85" stroke though) and i would probably end up doing a 3stage nitrous setup, probably like 75/100/125 at 3400/4200/5000
gasket set - ~200
daniel the first thing you need to do before you do anything else is gears. that is first on your list. then a good stall, then headers, exhaust, cam, etc. gears are first and formost. if you do actually get the 3,000 I would just buy a used supercharger kit from soeone on the board. you will see the most gains from that. then down the road you could build a forged low compression 355 and crank up the boost.
CARiD
Jul 7, 2015 08:19 AM
